- 6 Mar 2013
Hi folks, I'm looking to upgrade my motherboard, processor, memory and storage for my system and I could use a sounding board to tell me if I am looking at the right parts or not. I'm not very knowledgeable with this kind of stuff although I do know enough to get me by.
My current system is as follows so the only thing I am really keeping is the power supply and the GPU
GIGABYTE G1 Sniper 2 Motherboard
I7 2600k CPU @3.4 ghz
ATI Radeon R9 290X Sapphire Vapour-X Edition 8GB GPU
16GB G.Skill Ripjaw X RAM
Windows 7 64bit Operating System
CM Storm Trooper Full Tower Case
Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-515-GI&groupid=701&catid=5&subcat=2875
One thing I really want when looking at a motherboard is that it must be ATX (as my case does not support EATX), it must not use Realtek audio codecs and preferable but not a dealbreaker is I like having a killer network card in it. This motherboard seems to me to do everything I need it to do.
Processor
I was tempted to go back to AMD seeing as their processors seem to have more cores and are faster out of the box but none of them seem to be able to handle DDR4 RAM so it'll have to be Intel.
http://www.overclockers.co.uk/showproduct.php?prodid=CP-546-IN&groupid=701&catid=6&subcat=1672
I was a little disappointed that the speed was so low on this thing but everything I have read says that this processor is better for gaming than the two models above it plus I am somewhat limited in the budget for this build.
Memory
http://www.overclockers.co.uk/showproduct.php?prodid=MY-095-GS&groupid=701&catid=8&subcat=2557
For some reason I like G.Skill and they seem to be the cheapest around for the speed you get from them.
Storage
Boot Storage
http://www.overclockers.co.uk/showproduct.php?prodid=HD-130-OC&groupid=701&catid=2104&subcat=2198
Mass Storage
http://www.overclockers.co.uk/showproduct.php?prodid=HD-413-WD&groupid=701&catid=14&subcat=1955
Cooling
I couldn't find what I was looking for here on Overclockers so I had to go elsewhere for this.
No competitor links.
I could also go with a heatsink as my system currently has a very good one and I have no issues with it at all but my preference would be to go with a watercooled solution, I'm just not into setting up a full custom loop right now.
So am I looking at the right stuff here? My budget for the upgrade is around £1000 to £1500.
Motherboard
Processor
Memory
Storage
Boot Storage
Mass Storage
Cooling
