Hi,
Just wanted your thoughts on the below diagram really.
The case is a Lian Li A05b, and is part of my G505B project so will need to think up a new way to cool it, i was thinking along the lines of having 2 x 120mm fans set into the bottom sending cool air straight through the cpu cooler, over the motherboard/ram/nb/sb and onto the back of the graphics card.
Then having 2/3 x 120mm fans set into the roof with one at the rear of the case all drawing warm air out.
What are your thoughts? and will it work?
