Advice with a Starter Setup (2.1 to 5.1)
16 Jan 2012
UK
Okay, after my thread last Friday, I did some more research, and due to the lack of any decent looking HTiB's, I've relented to the fact that even a 2.0-2.1 system will sound much better than one of those, and leave me able to expand to 5.1 in the future. It'll be used for movies, TV, PS4 & PC.
I'm by no means an expert, so I need advice on the components I've eyed up, and if any money could be saved without affecting quality (compared to the current list). A note on the L/R speakers is I chose those for their 15cm width, look, reviews and price point, as size is important:
Receiver: Pioneer VSX-531-B 5.1 AV Receiver with Bluetooth
Front L/R Speakers: Q Acoustics 2010i Bookshelf Speakers (Pair, Graphite)
Centre Speaker: Q Acoustics 2000Ci Centre Speaker (Graphite)
Subwoofer: Pioneer S-21W 160 W Peak/100 W RMS Active Subwoofer (Black)
Total: £464.73 (£470 with some speaker wire)
Including the wire, is that all the needed components? Never set one up before as you can tell :p
Like I've seen a good deal of online comments saying, a 2.1 system should destroy any 5.1 HTiB around the price range, and the few that I have "liked" the look of are the same price. Advice very much appreciated! :D
Never had Pioneer so don't know how well they match against Q Acoustics.
I would save up for a better sub. A crap sub will make your system sound worse, and I'd rather have no sub, than a crap one.
You will need speaker cable, HDMI cable. Possibly coaxial, optical, RCA cables. Also recommend banana plugs.
Yup a stereo/2.1 system that is the same price as a 5.1 system will sound better.
Obviously a bit more, but an excellent lower priced sub is - Wharfedale Diamond SW150. I have it with a full compliment of the Q Acoustic 20xxi speakers. 2000 as the centre, 2020 as the fronts and 2010s as the rears.
All paired with a Sony STR-DN1050.
Im very happy with it.
I would give Richer Sounds a ring, because they have the 2020s priced at £79 if they have any left.
That sub will be dire. Save some pennies (400-500 quid) and buy something with some go in it.
Are you recommending spending 400 on a sub alone? I could spend more if needed, but I don't need anything too fancy, can't bring the walls down :p
Obviously a bit more, but an excellent lower priced sub is - Wharfedale Diamond SW150. I have it with a full compliment of the Acoustic Solutions 20xxi speakers. 2000 as the centre, 2020 as the fronts and 2010s as the rears.
Seems like everyone is in agreement in regards to the sub, I'll eye another, but unfortunately, the Wharfedale one looks a tad too large width wise :/
Those 2020's, are you referring to Q Acoustics? (not sure if solutions is the same company), I believe the i's are just more compact, but £21 saving isn't bad, could go to a better sub/avr!
Thanks, any recommendations for a sub? I suppose I'd be comfortably going up to £200 on the sub for now, which is double that allotment, unless that would be better suited going on the AVR?
Amended :)
Not sure what the i means but my reading when buying said 2020 front and 2010 rear if together, but if just having 2.1 or 3.1 then the 2010s with a good sub are still an excellent choice.
I have the same amp but running 2020i instead of 2010i and im more than happy with them.
In the market for a sub myself, Im looking at second hand to get a better sub for a decent price as like many have said dont go for a cheap sub its worth investing in a better one.
Dont mean to hijack the thread but while on the subject of subs can anyone comment on the kef psw2000 and the B&W ASW308? Obviously they are a few years old now but i can get hold of them for just shy of £100 refurbished locally. They worth a punt or not worth the money?
I've had and got some kef subs , the old PSW i had repaired twice , subs take a battering , and as they get old things like glue etc just fail , the 3005 sub i have has never given me any issues ..yet !
