EDIT: IGNORE! Looks like the controller needs a little squeeze where the battery is and it works!
Hi,
Just got the Kolink Umbra case fan set because my older Kolinks were dying.
I have installed the hub to SATA, fans and LEDs to the hub and the hub NOVS to LED, VDG and FAN on the motherboard. (Motherboard is a methuselah-old Aorus Z370 Ultra Gaming)
However while the fans work and light up, they are in sound control mode only and the remote control doesn't work. I've changed the remote battery and no difference.
Is there any specific software I need to install? The Kolink website isn't the easiest to navigate.
Cheers!
Hi,
Cheers!
