Okay, so basically I had a normal LCD for quite a while it, then the screen randomly started getting a big white streak across the screen. So I used the warranty a year before ending.
They took it away, a week later, they tell me that I only have £109 to spend from their store (the monitor I had cost me £160); which left me with literally only two choices, essentially only 1.
http://i.imgur.com/ELKTv.jpg
Old monitor was nearly pitch black
http://i.imgur.com/D47Mh.jpg
Inverted/deep colours at the top, washed-out colours at the bottom.
This is when I'm centred to the screen too, not under or above it.
Is this normal for an LED-lit monitor, and how are the specs? It's an ACER S220HQLBBD.
I want to see what other people think about the monitor and pictures, before I rage at the store on Monday.
