- 9 Aug 2020
Hi
I'm a little bit puzzled on what to do with my setup.
I have a Nad T778 AV receiver
I'm running a 7.1 setup with Tannoy precession 6.4 and matching center as fronts (no need to mention other speakers)
I have just bought some Focal 906 speakers with the idea of using them in a stereo only listening room.
I would like to use the T778 to run the Focal 906's.
Unfortunately Zone 1 & 2 don't allow use of blueos which I would need as I like to stream via Tidal.
I also own a Emotiva XPA Gen3 with 3x power lanes. I have been using this to power my 3 fronts, but if I'm totally honest I'm not hearing any difference, which tells me the T778 is powering them adequately.
Should I buy a stereo Amplifier without power and just use the EmotivaXPA to power the 906's
Or is there some way I can link my 906's with my T778 to save money etc.
I'm only still considering the T778 as I've read it's fantastic with two channel stereo and I wouldn't want to spend anymore than £800 on another amp if needed, which I feel with that budget the T778 could be the best route.
Thanks for any help
Thanks for any help
