I've just started to overclock my new setup and I'm a noob so please be gentle! The only thing I have changed so far is the RAM timings to the recommnded timings ([email protected]) and have set the vcore voltage to manual and 1.36 (default... I think!), and I have increased the FSB to 1500MHz (375x8) so have got my E6420 to 3GHz and all temps are looking ok 46 degrees or under after 30mins cpu stress test on Orthos stress test.
However I went up to 3.1Ghz and tried Orthos but failed, however my temps are fine - sub 45C. After having a bit of a fiddle I noticed that it crashes out on the blend test at lower speeds (~2.9Ghz) but it passes the small FFT's (cpu test) test up to 3.1. Does this mean its my Ram holding me back? What should be my next step? I would guess upping the voltage but I dont want to increase it too much cos i'm a cheapskate who cant afford new kit
. If so what voltage should i increase - RAM or VCore, and by how much? Thanks.
PS. Overclocking rocks!!! I really enjoying getting more out of my system than intended - it's like robbery
*edit. And is Orthos supposed to be jumpy as hell when you set it to a priority of 10 or is that a sign of instability? its fine on the same test at a different priorities
. If so what voltage should i increase - RAM or VCore, and by how much? Thanks.PS. Overclocking rocks!!! I really enjoying getting more out of my system than intended - it's like robbery
j/k it won't change your bill in any way really as in the big scheme thats a miniscule change, maybe a few more pence a month if that.
