Hiya,
I was doing a clean up of inside on computer(specs below) and I removed a fan from the motherboard (power unplugged). I cleaned the fan, placed it back into the exact same spot. Went to turn on the computer and it started up but then powered off. Did this for everything I tried.
Tested CPU/Motherboard with no ram/harddrive/graphics card/ all in different combinations and no success on boot. Tested my parts on a spare machine and all worked fine. Think the motherboard is blown... sending it back as its still under warranty until end of this year but it could take up2 28 days.
I am wondering whether I should consider buying a new mobo to replace to just wait out the 28 days. Looking around on forums I can see there is new chipsets on the horizon.... should i wait?
Spec of current;
Q6600 G0 w/ Ultra 120
Asus P5E X38 Motherboard (Sending back to supplier)
BFG 8800GT OC 512MB Graphics Card
2 x 160 GB Hitachi Hard Drives
4GB Patriot Extreme Performace Mem. 4-4-4-12
Hiper 620W Power Supply (Non Modular... pain in arse but good supply)
Advice on what i should do is much appreciated.
Spec of current;
