Advice
3 May 2012
Hi
Need some help on a motherboard i have currently a p6t delexe v2 and a intel i7 process 950 socket i belive the motherboard is a 1366 and it seems my motherboard is on its way out. Can anyone help me out with a decent motherboard that will work with my processor and my 1600mhz ddr3 ram. Dont want to pay huge amounts as only a student but it must be able to play swtor and terra online games. My graphics card is a ati 6950
kind regards
wes
Hi.
There are only two socket1366 boards available new at OCUK - http://www.overclockers.co.uk/productlist.php?groupid=701&catid=5&subid=1692&sortby=priceAsc
As you can see they are rather expensive.
An alternative is a B grade (90day warranty) item that might be missing bits, but as long as the board+IO shield plate and any other unique items are present (SATA cables cost pennies and manuals can be downloaded) then they are much cheaper.
http://www.overclockers.co.uk/showproduct.php?prodid=BG-404-AS&groupid=595&catid=689&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=BG-143-GI&groupid=595&catid=689&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=BG-506-AS&groupid=595&catid=689&subcat=
thanks for advice i see the guerilla one dosent say if it will take my 1600mhz ddr3 ram. it mentions all the others but them. Do you know if it dose or not?
