Advice
25 Nov 2011
Flat Norfolk
I have a problem with my screen resolution which I suspect is quite basic but nevertheless eludes my pro laymans expertise.
Ever since I installed a twin frozr gfx card the resolution will randomly (random to me), drops to something like 600 X 400. In the display settings there's no option on the slider for the screens native res. (1680×1050) when this happens. Auto detect also fails to shift it.
When it first happened it resolved itself after reboot and one time it sorted itself out after I rolled back some windows updates. Last time it did it none of these worked and eventually sorted itself out a day later after some new windows 7 updates were installed.
It's a 'PnP generic' monitor whatever that means.
Is this specific problem common, might there be an easy / simple fix. Buying a new monitor might be reasonable, given that I've just splashed 250 enhance to up the visuals.
Advise, and suggestions to buy a new monitor happily appreciated :)
