Advice
4 Oct 2012
Hi there looking for a cooler for my cpu its a 4770k what offers the best value for money and when i buy the cooler you recomend do i need to buy thermal paste etc.
need to know what motherboard and case you got before any real advice can be given, but some of the following after market cpu coolers are good ones to have.
corsair h80
corsair h100
phanteks PH-TC14pe
Akasa Nero 3 V2 CPU Cooler
Be Quiet! Dark Rock 2 CPU Cooler
Prolimatech Panther Premier CPU Cooler
Prolimatech Megahalems Plus 120mm Fan
Alpenfohn K2 Mount Doom CPU Cooler
please bear in mind that some of these cooler may not install correctly on some motherboard or will not fit in you case.
Best value for money is the K2.
Another suggestion would be a PH-TC14PE, in red.. That would look stunning with your motherboad.
Though really it will look stunning with a h100(i) in the top with some SP120's Red rings.
Actually the H110 is on offer. It will fit. :)
If you want more RED, you can get some wing boost red clover fans. :)
Yummm!
The h100i has better tubing, better fans and a nicer looking block but performance wise, its only a little better. The pump is the same.
The H110 is a 280mm version (using 140mm fans). This improves on the H100i.
You mean the refurb h100, for £45 its a great cooler. I would get some extra fans though, the stock ones are pretty noisey.
