Advice
23 Dec 2014
Burgess Hill, West Sussex
Hi,
Sorry to be asking questions with my first post but there seems to be lots of great advice on here.
I have been watching with interest the release of Elite Dangerous and I would love something to play it on. I also used to like flight siming. My current laptop is an i3-2310M with no dedicated GPU so not up to the job.
Having thought long and hard I think I would prefer to stick with a laptop even though I mainly use my laptop like a desktop.
My budget is around £600 and looking around I see I can probably get an i5 with a GT840M GPU and 8GB of RAM. Any idea what Elite would run like on this sort of setup and any pointers of what setup to buy.
Finally would I get a much better desktop setup for £600 compared to a laptop?
Thanks in advance
Hi and welcome,
I cant help with finding a laptop as I dont pay much attention to them.
But I can spec you a pc for £600 certainly.
What parts are you looking for? tower/OS/keyboard/monitor etc??
Hello & welcome to the forum :)
I have not kept up with the latest range of laptop graphics but I still believe that for £600 the desktop will be more superior and have a easier upgrade path.
If you did go with a desktop would you need a monitor and Operating system?
Hi, yes I would need a Tower, OS and Monitor. I wouldn't mind getting a usable setup to start with knowing I could upgrade GPU, Monitor or RAM at a later date. Not sure if I could handle a full build, I've changed GPU's, RAM, Drives etc. in the past but never done a build from scratch.
I was asked just a week ago to spec a laptop for gaming for close to that amount. Looked at several sites, nothing I saw was on a par with what you could get with a PC. Dual core i5M and 850M was best I saw. Also, I see people regretting buying budget laptops for gaming quite often, so have a good think before buying. Ideally you'd want to spend £700+ for a gaming laptop, whereas you could have the same performance or better with a £600 PC, which would also be more upgradable.
Firstly many thanks for your replies
I've been looking round and doing some research and although I first said I would prefer a laptop from looking at what I can build for the same cost it's a no brainer to go desktop.
I found some decent ready built machines but I'm really keen to build my own, just a little worried I will get something wrong. I have no problem at all with the physical assembly, I just worry about setting everything up correctly like RAM and HDD configurations.
Looking into the spec above it looks really great. I just have a few questions and possible changes.
1 x MSI AMD ATI Radeon 7950 BE 3072MB PCI-Express Graphics Card **REFURB 90 DAY WARRANTY** (R7950-3GD5 BE) £85.99
The performance of the card looks amazing for the price but what exactly does refurb mean?
I have just dug out of the loft 2 X Seagate Barracuda 7200rpm 320GB Hard drives from my old system P/N 9BJ14G-505. Assuming these are O.K as storage drives is it worth re-configuring with an SDD and how would all these drives work together?
I know I will get the bug and will be looking at upgrades in 6 - 12 months time so what is the system above going to be like for upgrades?
Lastly I have always been into Nvidia / Intel. What would a similar performance system look like cost wise?
These are repaired cards from the manufacturer rather brand new variants.
The drives would be ok, but you can configure them in RAID 0 which combines them as one drive or keep them separate, a SSD will also be good.
Is your budget still around £600?
Just to let you know I recently bought one of the 7950 refurb cards (the twin frozr) and the only thing different to new on mine is a slight scratching on the cover so nothing terrible. Other than that it's fine so don't worry about the cards condition. For a budget like yours I couldn't recommend a better card :)
RJCs spec is darn good. The case is the only weak thing but for £20 you won't get much better. Overall the spec looks solid. SFCASE is valid until the 31st so be quick.
