As per my signature I currently have a Inno3d GTX 1080ti X3 Ultra and an Acer 38” 3840x1600 ultrawide with FreeSync with an operating range of 48-75Hz.
I don’t game as much as I’d like, I’m completely redoing my build with an Asus ROG theme and am thinking of selling the GTX1080ti in favour of an Asus Strix Vega 64 to complement the rest of my build.
Of course I’d like an Asus RTX 2080 but the pricing on even the non-OC Strix version is ridiculous, I simply can’t justify it!
Looking at vertical GPU mount in the Evolv X and have the Phanteks 220mm PCIE extension already.
Any advice would be gratefully appreciated?
- With GTX1080ti stock running out and used prices on eBay being fairly strong (not enough posts for MM) should I sell (effectively swap) the card?
- Will I see a noticeable FPS reduction in games, given the 75Hz cap of the monitor?
- Existing build will go to son as a gaming PC and for schoolwork, thinking of an RX580 8GB as he uses my old 27” 1080p 144Hz monitor, or is this overkill given he mainly plays Fortnite as I also have an old GTX780ti hanging around
), but yes the Vega 64 would do the job if you're really that keen. You'll have to turn down some settings to hit 75 fps a lot of the time, but then you'll get used to lowered settings. Free sync should also help make drops in fps less noticeable. If you decide to stay with the 1080 Ti until 7 nm AMD cards come out, you can use borderless full screen to at least eliminate screen tearing without Freesync.
