advise for a case to fit a Asus P6T7 WS Intel X58 (LGA1366) motherboard
19 Jun 2009
i'm in the middle of making my own bespoke desktop computer ( as i think that getting off the shelf will not work for me)
the motherboard that i want to have is the Asus P6T7 WS Intel X58 with LGA 1366 socket type as seen here:
Code:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-338-AS
problem is what case should i go for, as i want one that will have the space for the motherboard and cards and size needed to expansion (for extra things like extra graphics cards, water cooling ect )
people all over the net have suggested cases such as:
antec titan 650
coolmaster storm sniper case
dunno which one to get, as i want one that will fit around the motherboard as i don't want to spend a lot money on a case then to find out that it doesn'y fit or won't work for the motherboard
so can i have you opinions and suggestions (which will be most appriciated) on what case should i get that will work for this motherboard and what i have in mind for it
Hang on...
WHY exactly do you NEED an P6T7? Not really the place for me to ask, but it's best to know what you need it for before saying "want that one".
And any case that supports ATX will take it, but you might need a longer case if you want to put long GPU's in (as I expect you would, if you're using a workstation board).
