Advise for a whole bunch of navigation buttons!
8 Nov 2008
Lincoln
I'm writing something for work which will assist in training personnel. We use Programmable Entry Panels which have a grid of buttons, with a lot of the buttons changing what you have on the PEP itself.
This was an early version before a lot of the editing, but gives you enough I think.
When you press a button on the 3rd row, it changes the entire section of 24 buttons below it. I created a similar one a while back, but there was only about 20 pages total so I just created a separate .html for each page. I'm thinking, however, that maybe <div>'s would be a better way forward?
Basic format is a table of 3 columns and 6 rows I think. Buttons are made from ul/li tags and css. Some cell spanning is used so each area could be controlled individually if required.
Any thoughts on the best way to proceed?
OK, trying to do this with a javascript function i've used before, but I can't seem to adapt it to this scenario...
JS:
Code:
function buttonpress(){var select = document.getElementById('functionarray');
var ais = document.getElementById('aispep');
var RADAR = document.getElementById('radarpep');
var option3 = document.getElementById('select3');
var option4 = document.getElementById('select4');
var option5 = document.getElementById('select5');
var option6 = document.getElementById('select6');
switch (select.value)
 case "ais":
 aispep.style.display='block';
 radarpep.style.display='none';
 option3.style.display='none';
 option4.style.display='none';
 option5.style.display='none';
 option6.style.display='none';
 break;
 case "RADAR":
 aispep.style.display='none';
 radarpep.style.display='block';
 break;
 case "option3":
 option1.style.display='none';
 option2.style.display='none';
 break;
Concept for the buttons is the third row changes the bottom left section of 24 buttons (functionarray), an exert of which is here:
Code:
3rd row:
    	<td id="borders" width="675px">
<ul id="nav" onclick="buttonpress()">
	<li><a>TAC</a></li>
	<li><a>LINK</a></li>
	<li title="RADAR" value="RADAR"><a title="RADAR" value="RADAR">RADAR</a></li>
	<li title="ais" value="ais"><a>AIS</a></li>
Function Array:
        	<div id="aispep" style="display:none;">
<ul id="nav">
	<li><a>ALL</a></li>
	<li><a>A CLASS</a></li>
	<li><a>B CLASS</a></li>
	<li><a>ATON LIST</a></li>
Nothing comes up on the debugger, i'm at a loss as to what isn't working...
Not sure if I've understood, but I'd be going with a <div> for each button, perhaps within a flexbox container? Would allow you to use javascript to edit the CSS and change the order of the buttons using flex-order, and hide buttons using display:none?
There was a great flexbox article on CSS-tricks here if I've actually suggested something useful!
