Advise On A CPU, MOBO & Memory
30 Dec 2010
Cloud 9
Hi guys
Time to upgrade again.
Hearing lots of stuff about Intel and AMD CPU's and im so undecided.
Can someone suggest a CPU, MOB and Memory, no other parts needed as of yet.
Many thanks.
If that budget is just for the CPU/RAM/mobo then this is around where I'd be looking for gaming and VR:
My basket at Overclockers UK:
Total: £708.97
(includes shipping: £0.00)
You can put the extra £90 towards a 250GB NVMe drive for your OS install, or upgrade the (actually rather decent) motherboard to something more high/mid-range.
Hi guys
Many thanks.
If gaming is your main concern, go for an 8700k build. It's the best overall gaming CPU available.
Total: £813.47
(includes shipping: £10.50)
If you were wanting to push for very high overclock, this would be a great motherboard and RAM.
You could save some money on a cheaper motherboard, and also do expect 8700k prices to drop £~20 as stock becomes more plentiful in the coming weeks.
Also, What resolution and refresh rate are you playing at?​
Total: £813.47
5760x1080
Would this system be ok at that resolution ?
5760x1080
Yeah, but since you have a Corsair H70 I would get a cheaper motherboard as you won't be able to keep very high overclocks at low enough temps.
You could go even cheaper on the motherboard, but I wouldn't spend less than ~£130 if you were getting an 8700k.​
