I am going to build my first pc
I have stripped and rebuilt my old PC many times in regards to taking apart cleaning and replacing parts that have failed . so although i would consider myself a NOOB when it comes to computers i do know what goes where to look at but know nothing else
I guess the only thing that is daunting is the cabling and a slight worry of compatible parts . If you have some advise i would really appreciate it
i also want to keep some old parts from old pc if possible ... MY PSU failed a week or so ago but the pc did do me great service.Only in the past two years ,did i find it hard to play games .. I only really play the fallout series world of tanks and ships ..the rest of the games i play are old more basic strategy games like hearts of iron 2 but i think with the new card i would venture into more power intensive games but like old skool games
My first question would be:
is 8gb of ram DDR3 corsair ams3 ( 1600mhz ) still ok to keepin the new build , to save money on a new build ..will this be enough for the foreseeable future ?
MY components i wanted to get are as follows - i am not sure what case i need to get or PSU ... the CPU fan also seems to be a problem for me to decide on ...some help would be good
i want to base the PC around these components ... these are a must have but the rest needs to be a sacrifice to maintain my budget
AMD Piledriver FX-8 Eight Core 9590 Blk Ed 4.70GHz (5.00GHz Turbo) (Socket AM3+) Processor - OEM
MSI 970 Gaming AMD 970 (Socket AM3+) DDR3 ATX Motherboard
Powercolor Radeon R9 390 PCS+ 8192MB GDDR5 PCI-Express Graphics
I am not sure about the POWERCOLOR as a brand - is there any difference between brands in this range ..personally i like sapphire ( previous cards and never broke and i have owned a few )
i believe the recommended PSU is about 750w .. or do i need to go higher as the CPU is 220 ? do cheap brands cut the mustard or should i stick with better ones ?
the CPU COOLER - i do not want to have a a liquid cooler , i am a lazy person who just wants to plug and play- with the odd cleaning duty ... the CPU from what i read is very HOT and a 220w fan is needed ... the only one I can see is the artic freezer 13 pro but can't find it on sale not even on the site , i think it's end of line ... the rest of the CPU fans i have seen have little spec out-lining the cooling spectrum of cpu's .wattage ..
my final question is do i need to buy cabling ? i assume all the cabling will come with the relevant component ?
any help would be great -
i have just gone for the top amd processor but did read it is just the 8350 facorty clocked ... is it worth getting it ? or will it be superseded
