Advise on cooling kit
4 Apr 2006
Norwich
Hi all
im thinking of getting this kit as the size and ease seem to fit in with my needs.
http://www.overclockers.co.uk/showp...unted Watercooling Kit (Socket 939/AM2/LGA775)
the one thing im interested to know (i know nothing about watercooling as yet) is the heatsink that comes with the kit any good? or should i replace it?
if i replace it will it automatically fit the tubing / and connections with the kit or do i need to look for somthing in particular to make sure it will fit?
thanks in adavnce
loki
All the reviews from the people that have bought it seem to suggest they are happy with its performance.
Why dont you buy it and 'suck it and see'?
If not happy you could then buy a better block and get the barbs to match the tubing size supplied with the kit?
I'd go for a thermalright TRUE with a couple of fans attached... You'll get the same cooling ability, cheaper and simpler.
