Hi all can i ask for some advise on increasing voltage to my CPU on a system supplied to me by Overclockers last week please.
system supplied
System Specification
- Case: Antec 300 Case with Purple LED Fans
- Power Supply: OCZ ZS 650w PSU
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Intel Z68 GEN3 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: OcUK H2 Flo CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Choice of DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
It also has a 60gb ssd drive supplied
Plus a AtI radeon hd 6950 2048 graphics card
plus win 7 operating system.
I contacted tech support and reported i was getting BSod`s the BSOD`s error code is 000lots ending with 0124
this was occuing first when launching game applications and the heaven test not occuring at the exact same spot sometimes as it just starts sometimes after a period of time and i have had a few occur just with windows running.
The machine runs fine with prime 95 and intel burn test no probs at all and overclocks as it is supposed to. Plus i have noted if i leave prime 95 running its does not seem to go wrong as much.
A chap replied to my webnote from ocuk tech support
saying Sounds like you need to up the CPU voltage a little
Not being an expert i thought i would ask about doing this as i looked in the bios and its set with an OCUK profile which gives you the settings as supplied .
Am i able to to adjust the voltage withought affecting the ocuk profile?
If so how exactly, is it in the bios or is there software on the motherboard cd i can do this in windows.
Also how much do you adjust it by i noticed in the bios its states 1.36 volts
how much do you increase it by and where and is there a safe limit? i must admit to be a bit confused reading the sandybridge thread in the main forum as there seemed to be many contradictory posts on voltage values.
Also is they a point when if the bsod`s still occur one has to say its not cpu voltage thats the problem.
So my question is how would i actually increase the voltage and by how much and will it affect my ocuk profile
Your help would be apreciated in how to do this as i would rather ask an expert than do it by guesswork
many thanks in advance
Sabina
system supplied
Sabina
