- 23 Feb 2012
- westyorkshire, Bradford
hi all
had a problem with the temps on this gpu, some of you may know in my other thread but i think it needed curing time for TIM anyways need some advise on checking my oc on the gts 250 not sure if there wright and that if im using the wright software.
first time overclocking just testing.
my spec
CPU - Intel core duo E7200 OC 3.2Ghz
RAM - 4gb ram
Motherboard - Gigabyte g31m-es2k rev 2
Graphic Card - PNY GeForce GTS 250 XLR8 512MB Performance Edition
SOFTWARE
msi afterburner drive version 9.18.13.3221.332.21
Stress Test Software
MSI Kombustor - using
FurMark- haven't used yet
CPU -z cupid
techpowerup gpu -Z 7 0.7.8
Benchmark Software
heavens benchmark 4.0
3d mark vantage
Tomb Raider in game bench mark
gts 250 stock
Core clokc 738
Memory clock 1100
Bandwith 70.5 GB/s
Shader 1836
oc
Core clock 770
Memory clock 1400
Bandwidth 89.9 GB/s
Shader 1890
ok this is how im doing it but im a bit concerned im might being doing it wrong
i first raised my core to 800 and i sued Kombutor where it detected artifacts so i lowered it till there was no artifacts at 7770 mhz.
i than started on the memory step by step until i ve go to 1400 which seems high compared to other peoples in the forum and their no artifacts in kombutor at all, im i doing this wright.
should i keep upping the memory until i get artifact or a crash in kombustor or im using the wrong software t o test the memory.
don't wanna keep going if its wrong so i stopped and thought i would ask.
my spec
RAM - 4gb ram
SOFTWARE
CPU -z cupid
Benchmark Software
3d mark vantage
gts 250 stock
Core clokc 738
Memory clock 1100
Bandwith 70.5 GB/s
Shader 1836
oc
Core clock 770
Memory clock 1400
Bandwidth 89.9 GB/s
Shader 1890
