Aego M + Audigy?
23 Oct 2004
London
Hi, I'm about to order some nice shiny Aego M 2.1s, but I'm not sure if I should upgrade to an audigy card (currently using onboard sound).
I don't really want to spend much on a card as buying the speakers is a treat anyway as I've just been paid, so I was thinking of the:
Creative Sound Blaster Audigy SE 7.1 Sound Card - OEM (SC-040-CL) £19
or
Creative Sound Blaster Audigy 4 7.1 EAX Sound Card - OEM (SC-037-CL) £35
Questions:
a) Will I notice a decent upgrade from my onboard with either of these cards?
b) is there much difference between the two?
Thanks in advance!
Hello there.
i have the Creative Sound Blaster Audigy 4 7.1 EAX Sound Card - OEM (SC-037-CL) £35 and the Aego M 2.1 and i did have onboard sound . the difference is like day and night :D .the sound is soooooo much better .go for it mate you will be well pleased with your sound after you upgrade ;)
and there on THIS WEEK ONLY .so get them while there down in price ;)
I would reccomend saving a little more to get the best out of the Aego's
recently picked up a X-Fi for £43 off an auction site. went from a Audigy 2 to it and the differance was incredible. really does make the Aego's shine
How? :p
Does the sub compliment the midrange produced by the satellites, without even sounding as though its there? With my current pc speakers, I can hear the bass coming from under the desk, which isn't how it should be really :(
