Aego M & XBox 360 Setup Help Needed
29 Sep 2004
Wilt of the Shire
I want to be able to connect my xbox 360 to these speakers as well as to my pc. Is this an easy thing to do? I assume I'll need some other cable to achieve this so any help appreciated.
Does your monitor/TV have sound pass through (when using HDMI)? if so, your best bet is to connect the Aegos this way. The TV/monitor should have an analogue audio-out connection that is either 3.5mm stereo (so plug your speakers directly into this) or L/R Phono (in which case, you will want to pick up an adapter that converts 3.5mm stereo to L/R Phono (RCA)).
Alternatively, you can use a "XBOX 360 AV cable" (which outputs sound via L/R phono (RCA)) and use it conjunction with a L/R Phono (RCA) to 3.5mm adapter. This adapter looks a lot like this one, but the 3.5mm end is female
