Im currently running my TV's via a 3-way co-ax splitter, but need to add another 2 TV's. All the splitter ports are currently used.
The only 5 port splitter I can find is a 5 way 'F' splitter. Im close enough to a major signal so don't need any amplification, I just wanted to know before I cut the end off every cable I have and rewire them to 'F' sockets if this is the right route to go down.
Can I take my co-ax cables, cut the ends off and fit an 'F' connector to them?
Is the 'F' connector any good?
Is this the right way to do this?
Just want a sanity check from the people on here that know more about this than me..
Cheers
Cheers
