Hi guys
Been lurking for a few days to try and get some ideas for my first build in a few years. There's some great rigs being put together out there!
I'm looking to put together an m-atx gaming rig that will hopefully do me for a couple of years. Budget is ideally around £800, but as you'll see below I've kind of blown that already!!
First question is does the build look OK as it is?
YOUR BASKET
1 x MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card £239.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £191.99
1 x Crucial M500 240GB SATA 6Gb/s Solid State Hard Drive - (CT240M500SSD1) £129.95
1 x MSI Z87M Gaming Series Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £119.99
1 x Aero Cool Dead Silence Gaming Black Mini Tower Windowed £72.95
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler £54.98
1 x SuperFlower Golden Green HX 450W "80 Plus Gold" Power Supply - Black £53.99
1 x Pioneer 24x Internal DVR-221LBK DVD Rewriter - OEM £14.99
Total : £949.81 (includes shipping : £12.50).
Second, any thoughts on where I might economise a bit? I think that the GPU is probably a bit overkill given that for at least the short term I will be using a 720p TV as a display...should I go for an R9 270x instead of the 280x? Also as I'm unlikely to o/c for a while could I just make do with the stock cooler rather than getting the h60 for now? Making these two changes would knock the best part of £150 off and bring the budget back into view.
Any help would be appreciated.
YOUR BASKET
