- 1 Dec 2013
Alright lads, I've got a slight problem with the fan controller mentioned above and I was wondering as to whether anyone else had had any problems with it.
Everything seems to work fine apart from the RPM adjustment feature. I cannot adjust any of the fan speeds and whenever I plug my CPU fan into the main fan feature it just propels it to about 3500 RPM and will not allow me to slow it down.
Has anyone else had this issue or am I just unlucky enough to be stuck with a broken unit which needs replacing?
Cheers in advance.
P.S I've also posted this in the Overclocking and Cooling Section as I'm not too sure as to which this problem applies.
Cheers in advance.
