Aerocool x-predator ultimate gaming case?
14 Feb 2013
I will soon be buying a bigger case and saw the aerocool x-predator and i think it looks quite good. its about £100 and wanted peoples opinions on it before i brought it, so whats your opinion on it?
I've got one actually. In white. It is very nice and very large, I wanted to avoid the blocky feel of other cases, this one seems a bit curvy?
Generally its great, if you want to know any specifics gimme a shout, i don't know what to go over.
It is very large though.
The only thing i will mention is the front header, bit strange.
The usb3 port is a bit strange, is good and bad. The usb3 is just an extension, its a cable run from the front to a usb3 port on the back of your motherboard. Which is a bit strange and inconvenient, but it also frees up the usb3 header for multiple connections.
The other peculiar thing is the 3 usb2 headers. The left and centre ports are controlled by a double usb2 header, the standard one. But the third one is controlled by a single one, just 4 slots. Which confused me a fair amount since it isnt int he manual. So just bare that in mind if you do get it.
Im not too sure, as im air cooled. but there is a huge 200mm fan at the top which could probably be replaced by a fairly large rad.
I know if need be, you can mount it on the outside, on the back 140mm fan bit, it does have the holes to feed tubes through.
