Permabanned
- 7 Jul 2005
- Suffolk
i just bought an aerosol can off the bay which is designed to clean dust from pc components. but worried its going to mess things up. if i hold the can still whilst spraying, only air (non liquid gas) comes out, but whilst spraying if i move the can, turn the can upside down or shake it, it throws out a liquid gas which avaporates within a thew seconds and leaves a small white substance. Im worried if the liquid stuff comes out whilst spraying the dust off my mobo ect, it will mess the components up. what you think?
on the item description on 4bay, it says it can clean mobo's ect. but on the can it only says, "dust between keys on keyboard, cdroms, printers, ect.
