Aerox 9?
18 Oct 2011
Anyone here use this mouse by any chance? At the moment i have a naga pro but as usual with Razer products it is starting to have problems and needs replacing. After around 6+ naga's i am leaning towards a new brand all together. The only thing that puts my off the Aerox 9 is the (13ms) click latency compared to the naga pro's (3.1ms).
Yeah razer are on top of the click latency these days probably due to the optical switches and its pretty noticeable if you play fast fps. Logitech are only slightly behind. The sensors on steelseries had never been great either, not sure on that particular one but they always seemed to choose non-perfect ones with accel years ago. Razer are currently going through their range making new superlight wireless versions - good chance they'll get to the naga eventually. Not much between the wired naga x and aerox 9 in weight I see (80ish). The wireless 115g naga might feel better on a faster pad like the Endgame Gear mx390, got a friend that wont move off the heavy deathadder pro until the new ones out
After looking in to the Aerox 9 more it was jus not viable for me, the side buttons sit a lot further forward over the nagas so would not suit my hand size or grip at all. Unfortuantely i bit the bullet and went with another Naga pro.. And believe it or not i had to send two back as one was opened and clearly used and the other had a broken right click. On receiving the third the side buttons did not work correctly (would get stuck) but i had my old 12 button side panel which still worked fine so kept it.
Overall this one works a lot better than my original one as the wireless has no connection issues upon waking, it feel insane still purchasing these products afer now having 9-10 but there is nothing close.
Wow was that from oc or another store? Usually you get the b-grade warning or like amazon warehouse for stuff open from bezos. Still not a great sign of razer quality control either but I guess it could be years old stock with how old the mouse is too. I noticed the likes of corsair haven't even bothered to make their MMO mouse wireless yet, with the wired one as heavy as the naga pro at 115g.
Might be worth keeping an eye on r/mousereview over at reddit for any leaks but probably won't be until at least the end of the year with the deathadder due September but already seen in the wild getting tested by some pros.
From Razer directly, yeah hoping they will do a updated version of the Pro or atleast another company will have a crack at it.
