Affordable twin output card?
7 May 2004
Naked and afraid
I'm after a card for pure desktop work, it has to have two outputs (preferably DVI) and capable of 2048x1152 on both screens.
I have had a look but images of cards aren't always correct and nore are specs, or so it appears.
Naturally I don't want to spend an arm and a leg, this is for a none gaming rig low power silent rig.
Thanks in advance!
I found a 2600XT PCI-E for £25, would that be better as it's less power, less heat and more cost effective.
From what I can tell it supports more than 2048x on both it's DVI outputs.
