- 5 Feb 2009
I want to add two 140mm front intakes to my Enthoo Pro M case to go with the single 140mm rear exhaust it already has.
I'm looking for PWM controlled fans that can spin down to quiet levels at idle but move some serious air when turned up. I'm not too bothered if they're a bit noisy at load so long as they're nice and quiet when my system is idle and doesn't need the airflow.
I was initially looking at the Corsair ML140s. At £30 for a pair they're not the cheapest, but not too expensive. Then I saw that the new Cryorig QF140 is slated to move more air at load (128 vs 97 cfm). I don't know if that's a reliable figure or just marketing guff akin to stated contrast ratios on monitors?
I had them in my basket here, but then I saw a couple of comments on review sites that the cables are very short, which would be a pain and would require me to buy extensions as well.
Then there's the Noctua AF14 Industrial, which goes up to a whopping 3000rpm. Surely very noisy at load, it seems they have a minimum speed of 2000rpm, which is not going to be very quiet.
I also looked at the Arctic Cooling P14 PWM fans, but there seems to be some inconsistency about the max speed of these - some places it say max of 1350rpm, others 1700rpm. I'd not want one of the slower ones if there are two versions. These are really cheap, though!
Any reason to prefer one over the other of these? Any other recommendations?
