after a new case
13 Jan 2006
Wigan
hi
i no there are a lot of these
but im after a new case for a new build in couple weeks
what i want:
size- after a big case, i dont want everything cramped in, i will be installing a 8800gtx and a sycthe ninja cooler. dont think i will water cool but u never no so the space for it would be nice
no window/lights, i dont want it lighting up my room
minimalist- my current case is the p180 so want a similar type of look but obviously different case.
and obviously want it to be a good cooler
and quiet
at the moment im looking at the Lian-Li PC V2000B PLUS, but am after some other options
thx for any suggestions
Heh was going to suggest the P180 :p May I ask why your going to change? I was considering that case :p
Anyways, other than the P180, the Lian Li PC-A10 Case looks good and is pretty quiet.
Infact, 3dgameman.com just reviewed it! I recommend that you take a look!
P180 is the worst case I have ever owned. Worst thing ive ever spend my money on in my life.
BlairH said:
I was thinking along the lines of a Silverstone TJ07/TJ09
TJ-07 looks awesome. Just a shame about the 92mm fans in the back. Thats the only reson why I wouldnt buy it really.
I think you should also consider looking at the Lian Li G70 or maybe the Akasa Eclipse 62 utajoker. The Eclipse is one of if not the best case that I have ever owned.
P180 is not a big case to be honest. A friend of mine has one and I really didn't like it that much. I'd go with either the Eclipse or a Lian-Li; I have the V2100+B and love it to bits, and I've also heard good things about the G70 and V2000.
p180 is a good case i just dont want 2 of them and it was a pain to build in.
the TJ09 suggested looks quite good i will have a close look at them, quite like how the whole back of the case comes out with the mobo tray
after looking at some of the others suggested
its def gonna be between Lian-Li PC V2000B PLUS and the TJ09
does any1 have any pics of builds in these cases?
thx
