I'm basically after a cheap lappy for the campervan. The last one died as it hit the floor in a hard braking maneuver
All i need it a reasonable screen and the ability to store and play some .avi and vobs....
I've been looking 2nd hand and there dosn't seem to be any bargins going that you couldn't get new for
Does this kind of thing look ok for £260 quid?
System Type Notebook
Processor Intel Celeron M 540 / 1.86 GHz
Installed Size 1 GB / 2 GB (max)
Built-in Devices Stereo speakers, wireless LAN aerial
Width 36 cm
Depth 26.7 cm
Height 4.3 cm
Weight 2.9 kg
Localisation United Kingdom
Processor
Data Bus Speed 533 MHz
Chipset Type Mobile Intel GL960 Express
Cache Memory
Type L2 Cache
Installed Size 1 MB
RAM
Technology DDR II SDRAM
Form Factor SO DIMM 200-pin
Configuration Features 2 x 512 MB
Storage Controller
Type Serial ATA
Serial ATA Interface Serial ATA-150
Storage
Hard Drive 80 GB - Serial ATA-150
Optical Storage
Type DVD±RW (+R double layer) / DVD-RAM - integrated
Card Reader
Type 5 in 1 card reader
Supported Flash Memory Cards SD Memory Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card
Display
Display Type 15.4" TFT
Max Resolution 1280 x 800 ( WXGA )
Widescreen Display Yes
Colour support 24-bit (16.7 million colours)
Features CrystalBrite
Video
Graphics Processor / Vendor Intel GMA X3100 Dynamic Video Memory Technology 4.0
Max Allocated RAM Size 252 MB
Audio
Audio Output Sound card
Compliant Standards High Definition Audio
Features Acer 3DSonic stereo speakers
Audio Input Microphone
Input Device(s)
Type Keyboard, touchpad, 4-way scroll button
Features Built-in numeric keyboard
Telecom
Modem Fax / modem
Max Transfer Rate 56 Kbps
Protocols & Specifications ITU V.92
Features Wake on Ring
Networking
Networking Network adapter
Wireless LAN Supported Yes
Wireless NIC Acer InviLink 802.11b/g
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g
Remote Management Protocol DMI 2.0, ASF 2.0
Features Acer SignalUp
Compliant Standards IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED
Expansion / Connectivity
Expansion Slots Total (Free) 2 ( 0 ) x memory - SO DIMM 200-pin ¦ 1 ( 1 ) x ExpressCard/54 ¦ 1 ( 1 ) x PC Card - type II
Interfaces 4 x Hi-Speed USB - 4 PIN USB Type A ¦ 1 x IEEE 1394 (FireWire) ¦ 1 x infrared - IrDA ¦ 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) ¦ 1 x display / video - S-video output ¦ 1 x audio - line-out/headphones - mini-phone stereo 3.5 mm ¦ 1 x microphone - input - mini-phone 3.5mm ¦ 1 x audio - line-In - mini-phone 3.5mm ¦ 1 x modem - phone line - RJ-11 ¦ 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
Miscellaneous
Features Security lock slot (cable lock sold separately), administrator password, system password, Disc Anti-Shock Protection System (DASP, wake on LAN
Compliant Standards ACPI 3.0
Power
Power Device External
Voltage Required AC 120/230 V ( 50/60 Hz )
Battery
Technology 6-cell Lithium Ion
Installed Qty 1
Capacity 44 Wh
Run Time (Up To) 2.5 hour(s)
Width 36 cm
Depth 26.7 cm
Height 4.3 cm
Weight 2.9 kg
Processor
Cache Memory
Type L2 Cache
Installed Size 1 MB
RAM
Storage Controller
Type Serial ATA
Storage
Optical Storage
Card Reader
Display
Video
Audio
Input Device(s)
Telecom
Modem Fax / modem
Networking
Miscellaneous
Power
Battery
Installed Qty 1
Capacity 44 Wh
