After applying compound, how long before card can be used?
3 Dec 2003
Kent, UK
Hi
I have removed the stock cooler from my GTS 8800 and cleaned off all the old compound and thermal tape.
Next step is to apply some new compound and reattach the cooler.
My question.... How long after reattaching the compound and cooler can I use the card again? Should I leave it to rest for a bit or is it best to stick it in and get it heating up?
w.
