- 19 Jun 2012
Hi all
Been preparing our master bedroom for decorating, and part of that process was to get the wallpaper off. It was horrible bubble effect anaglypta stuff, eugh.
Anyway, we have now discovered the reason for the paper - one wall is completely full of hairline cracks in the plaster, and there are cracks and ageing damage in other areas too. I suspect the main wall with the problem is something to do with the fact that the chimney is on that wall (externally only, the internal wall is flat). There is also signs of very minor water ingress on the ceiling right smack bang where the chimney would be and right where it goes through the roof (its a strange design)
Anyway, I was considering contacting a plasterer to come and skim all the walls but I am unsure whether the hairline cracks will also cause the new skim to crack in a similar way or would it be better to remove the original plaster and start again? That would be a massive job as it is best part of an inch thick and is affixed to a cinder/ash type block (all internal walls are like a cinder block in my house and produce a black dust when drilled that stains quite easily)
I don't want to over board due to losing space.
Additionally I have an artex ceiling that I want to cover. Fortunately the stipple pattern is very shallow but can it be plastered over successfully or is it going to have to come down and be reboarded? Again, I do not want to over board it really
