After weeks of your help .. Hows this ?
11 Nov 2007
You have all been amazing helping me with this build and I have finally put my list together.
Before I buy I wanted to run it passed you all first.
Intel Core 2 Quad-Core Q6600 G0 SLACR, 95W, S775, 2.40 GHz, 1066MHz FSB, 8MB Cache, OEM
Asus P5K Premium/WiFi-AP, iP35, S 775, PCI-E (x16), DDR2 1066/667/800, SATA II, SATA RAID, ATX
4GB (2x2GB) Corsair TwinX XMS2 Pro, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 4-4-4-12
512MB Asus 8800GTS, PCI-E 2.0 (x16), Mem 2070MHz GDDR3, GPU 740MHz, HDTV/2xDual Link DVI-I
250 Gb Western Digital WD2500AAKS Caviar SE16, SATA300, 7200 rpm, 16MB Cache, 9 ms
Pioneer DVR-215BK 20x DVD±R, 10x DVD±DL, DVD+RW x8/-RW x6, DVD-RAM x12, SATA, Black, OEM
you may want to consider the seagate 7200.10 250 GB HDD, they are single platter, so are faster then the WD 250GB
If your planning on oc-ing the cpu you may want to get a decent cooler, the Thermalright Ultra-120 Extreme is the best and a decent fan like Yate Loon.
Also get some good thermal compound like AS5 or MX-2.
Dont forget to get some sata cables too :)
as long as its a retail boxed MB, he shouldnt to buy more need SATA cables, but check manufacturers website/reviews to be sure
What are you planning on using the machine for, if gaming i would recommend going for the wolfdale instead of the Q6600... just a thought.
I am I have the Slight Knight 2 .. got good reviews on here !
Price is a little higher when i got that cpu and mobo xmas week. I got the retail quad for £152 and mobo for £117 now they are £170 and £140 just put a Freezer 7 pro on it and you can get 3.6ghz easy.
Yate loons don't fit onto the Ultra (I have both) unless I'm doing something wrong.
