Afterburner and Overdrive not matching?
27 Apr 2004
Doncaster, S.Yorks
Hey guys, ive just noticed my Ati Overdrive and Afterburner dont match up in terms of core and mem clock anymore, cant seem to work it out, normally if i changed one or the other it would change on both and be all fine, but recently its not doing that leading to some interesting moments in games when the core&mem jump around.
Afterburner settings are the same, so i have the sync box ticked and low level hardware checked, everything else is unchecked...
Anyone have any ideas at all? im mega confused.
should add im using 12.7 and ab 2.2.2
Hmm im surprised nobody here has nothing to add, its starting to bug me after a restart afterburner fails to see the CCC clocks and afterburner runs the card at stock speeds while CCC has the overclock speeds, so if i forget to check before running game it ends up running stock as afterburner seems to override CCC.
Cant remember what version i had before, but if i changed the clocks in either CCC or AB which ever one i changed it changed the other one.
Eg. Change the core clock in CCC - AB would see this and change at the same time and vica versa.
Edit- Should add im only really using afterburner for the on screen display, so i can check usage and temp etc, not bothered about all the other stuff that it has.
Okie dokie all done, i suppose it all works the same, so not sure why i didnt think of that before hand, think its just because ive always done it the way it worked for me :) cheers fella.
