afterburner and UAC
bru
bru
21 Oct 2002
kent
OK so I received my MSI gtx470 today, and so far I'm very pleased with it straight to 800mhz with 1.025v, custom fan profile and it ran kombuster for an hour straight with no issues.
But......now loads of people have sung the praises of MSI afterburner as an overclocking tool, and i must agree it seems to be very good and easy to use.
but please..... please....please tell me theres a way around the UAC msg every time i boot the machine. as its driving me nuts already.
You can also set it up to run using task schedulor in windows if you allow the program to run with the highest priority.
disable UAC i thought this was the first thing the majority of people did after installing windows 7?
you can set it up so you auto login aswell ^_^ and add a quick launch bar to the task bar
