Afterburner not detecting 980 ti
15 Nov 2014
Hi was looking for some help and advice, i have a 980 ti ocuk ref. Overclocks really well but in the last two weeks afterburner and 3d mark dont detect the card and im unable to do anything with it. Normally runs at stock so haven't been stressing the card. I'm stuck and would love so advice. Many thanks
I would firstly completely re-install the latest drivers with DDU
You can download the latest from the nvidia website.
I take it the card is working fine otherwise?
Thanks for the reply.
Yes tried that still no joy, it works fine and before this happened could get a nice overclock on it. Completely at a loss
Use DDU and try the driver before the latest version.
http://www.nvidia.co.uk/Download/Find.aspx?lang=en-uk
Other than that update the mobo bios to the latest version and re-install afterburner.
Does the GPU show up in other overclocking software like EVGA precision-X?
Or GPU-Z?
Its now working thanks for your help:D
un-installed everything then installed gfx card afterburner still doesn't work but precision x now works. Not exactly sure why but card is now running at full capacity. Thanks again
