Afterburner nto saving Core Volts
2 Feb 2016
East Midlands
Overclocked my GPU, periodically afterburner resets my core Voltage setting, remembers everything else but the core voltage keeps resetting which is worrying for stability.
Any ideas on the cause?
Just save it and use it as 3d profile and it'll work (afterburner won't show it in ui after boot, but it's in profile anyways and works).
Sorry I'm pretty new to this, can you expand in more detail please? No idea what 3d profile is referring to.
First save your desired values for voltage, core and memory speeds (I think you already have), then go to afterburner settings, and under profiles tab you can set it to you 2d or 3d profile. This will then use that profile when you launch games.
