Im wondering if anyone has had a similar problem.
When I enter certain areas ie Cannibal Caves or the Villas in Tarantia Noble I get a massive
frame drop for a nice 40fps to a slideshow 8 fps.
When I disable shader model 3 it runs great again. It only happens in these two areas and only with shader model 3.0 enabled.
I have set all the driver settings to default.
Spec in sig and 175.19 drivers.
