Ageia Physx card
25 Dec 2008
Birmingham
Been offered one of these for £30. Is it worth having, I am running a 9800GTX+ with a core 2 clocked at 3.4 gig? Will the 9800GTX+ just be as good on it's own or it is worth the £30 for the dedicated card?
Mainly play FPS.
Thanks.
If you want to play Mirror's Edge it's good value. They often fetch more than that second hand.
Performance is about as good as as running a 9600GT as a dedicated physX card. Apparrently it's a bit of a pain to get running though, as nVIDIA are only doing update drivers rather than a complete package.
