- 22 May 2015
Hi, my ageing system (6 years old) is starting to show signs that an upgrade could be on the cards. My current system is made up of...
CPU: Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366)
Mobo: Asus P6T Intel X58 (Socket 1366) PCI-Express DDR3
GPU: Sapphire ATI Radeon HD 6950 "Dual Fan Edition" 2048MB GDDR5
RAM: OCZ Reaper 6GB (3 X 2GB) DDR3 PC3-14400 (1800MHz) Tri-Channel
PSU: Corsair TX 650W ATX SLi Compliant Power Supply
HDD: Western Digital Caviar Green 1TB SATA-II 32MB Cache
Case: Antec P182 Super Midi Tower Case
I'm looking to spend around the £800/£900 mark is there anything worth keeping from my above system ? If anyone could kindly recommend some new components as I'm somewhat out of the loop with current tech.
I wouldn't need the O/S, monitors etc (current res is 1920x1200). Is it worth keeping the case, or ditching it for a newer one ? The upgrade would mainly be used for gaming.
Might be worth mentioning that I would prefer to go the SSD route as well.
