If my AM5 system is unstable with an AGESA 1.0.0.7a BIOS when the DRAM runs at 6000 MT/s, is that likely to be caused by the SOC voltage being limited <1.3v on the new BIOS versions?
If so, does enabling the liquid nitrogen mode (LN2 mode) allow the VSOC to be set at 1.3v or higher, and is that likely to result in a stable system?
Do we have any idea yet at which point the SOC voltage can cause Ryzen 7000 series CPUs to burn out /break?
My current AGESA 1.0.0.4 (beta) BIOS defaults to ~1.25 SOC when EXPO @ 6000 MT/s is configured. I've been running it at 1.3v for ages now (LLC at default), as I'm fairly sure this was needed for stability.
EDIT - I'm stability testing 1.25v as Anandtech said this was enough for their memory testing benchmarks (they tested with the latest BIOS version), with DRAM running @6000 MT/s "We eventually settled on 1.25 V on the SoC for this kit and our Ryzen 9 7950X3D, and we found stability in memory-intensive benchmarks was solid". Link:
Gaming Nexus also said that "one thing remains abundantly clear: the issue is not just one that relates to SoC voltage" - Regarding CPUs getting burned up.
