I haven't overclocked a graphics card since my GF4 Ti4400, so not sure if I am doing this right. Anyway I've had my 7900GS a few months now and thought I would try overclocking it using coolbits.
Stock settings are 450 / 660 and max temp is 62c
I increased the mhz of the GPU by 10mhz at a time (and pressing the test changes button) till I got to 575mhz then I ran 3dmark 05 to make sure it was fine. I increased the memory the same as the GPU till I got to 785 and the "test changes" said my overclock was to much so I put it down to 775 and ran 3dmark 05 ok.
3d mark05 Scores:
Stock: 6497 (450/600 - 62c)
GPU OC: 6791 (575/600 - 68c)
GPU+MEM OC: 6858 (575/775 - 68c)
I didn't actually keep going on the GPU till it said my overclock was to high but is a 125mhz increase on the GPU pretty good? should I keep going more? Also is the extra 3d mark points really worth it?
<edit> something else I forgot to mention, in the "2D" options, the memory is set to my overclocked speed of 775, even when I hit "restore defaults" then go back on the 3D bit and raise it again and apply, it saves it in the 2D bit to - is this normal?
3d mark05 Scores:
ahwell, 125mhz is better than nothing ;D
