AGP Card Plug - Noob Q
25 Jul 2004
Carmarthenshire, SW Wales.
You know on the Trailing Edge of a AGP Card pug there's that little bit that turns 90 degrees backwards and is outside of the socket? Whats that do / for!!?? ;)
Cheers :p Daniel :p
Thanks for the prompt responses! Sounds like the sort of thing and a neat idea. Never seen a clamp on a mobo for it tho! Cheers!
not all board have the clamp thingy but it is a very good feature. my old kt7a board does not have it and the case the board is in is crappy so if i tighten the scred holding the agp card in place too much then the back end of the card lifts a little out of the socket and caused boot problems sometimes.
if i had the clamp on the card then i would never have this problem, so i have to be very gentle when fitting the card in.
I used to take them off if i could with a small screwdriver, because before i had h2o,i would often want to play with different fans & gpu sinks etc.Needing to remove the graphics card in a full case could take some force,practically blind in a full case ,to flip the little lever.As my graphics cards became larger it began to become quiet unnerving when taking it out.It felt as if i was prising a capacator off or something close :eek: . If youre careful in removal (tape it to the inside of your case)you can replace it unnoticed for any reason necessary.I have never had a grafics card not want to stay in on a decent built PC.:)
just a suggestion.
