Typically, the last time I did a system upgrade, it was just before the entire PCI-E revolution broke. Foolishly (in retrospect), I chose to go ahead with the upgrade rather than wait for the new technology. Still, hindsight is, as they say, 20/20 and I'm left in an interesting situation.
I currently have the following:
AMD Athlon 64 3400+ (Skt 939)
Asus A8V Deluxe
1024 Mb DDR Corsair Value select
Radeon 9600 Pro (with aftermarket silent heatpipe cooler)
FSP Sparkle Zen 300W
Seagate Barracuda 160Gb Sata HDD
I'm looking to upgrade the Graphics card, preferably to something silent (although I can always fit an arctic cooler or an aftermarket heatpipe cooler), and wanted some advice on the route to go.
I have about £180 to spend, and so I'm not sure whether I should replace the AGP card for another AGP card, or whether I should replace the Mobo and go for a PCI-E card. Obviously, if I replace the mobo then that reduces the amount that I can afford to spend on the gfx card. But, it seems that bang for buck, PCI-E cards are cheaper. Obviously, the amount of power available is somewhat limited, due to the low power output of the Zen, but I like the fanless design (the missus hates a loud PC), and it's a very fine PSU for stability and economy. If I'm going to change the Mobo, then I am determined that it should have SATA 2, but Sli/Crosfire is entirely unnecessary.
So, what would you do? Which products would you choose?
Thanks in advance for your help!
Asus A8V Deluxe
