No issues.
really? i installed ide mode and then had to do a windows hack as was getting BSOD when i wanted to change back
.That's a different issue, if you install in AHCI mode you can switch freely back to IDE and forward to AHCI since the AHCI driver is already enabled, but if you install in IDE mode the AHCI driver doesn't get enabled on install hence you having issues.
