Permabanned
- 7 Sep 2005
I could do with some advice from you guys please?
My PC will not boot. In fact the little blighter will not even post the bios screen. The only thing that moves when powering up are the fans.
What happened? (In your own words sir)
Well...I was using Everest with the correct 'Clockgen' program for my motherboard when I noticed that the cpu frequency did not alter when re-setting the fsb using the slider.
I thought... oh....maybe just a reboot will fix it... reset the bios and all will be well?. Nope...now she wont boot up. The monitor just displays ' No video input'
I have checked the motherboard & graphics card for signs of little black smoke and all seams to be OK. The motherboard has the green light on but I cant hear any hard disk activity.
If any one has any ideas please could you post a reply....I've just ordered a 6800GS from Overclockers and it should arrive today so this will be the first thing to change.
I think I may have blown the motherboard, but I'm not sure, is there a way to check?
