having said that...dont think it will work on that pc if its for the pc in your sig
Try navigating to a more recent board and you can download it from ther, most of them have it listed. As mentioned not sure if it will play ball with your board though, but worth a try.
According to a post on the Asus forums:
"ASUS Ai_Suite V1.06.20 is the latest version offered for the M4A88TD-M EVO/USB3. Please note that this is not AI Suite II. "
A working link to that version here:
http://support.asus.com.cn/download.aspx?SLanguage=en&m=m4a89gtd pro/usb3&p=1&ft=14&os=30
Ah, you didn't mention Win10 and have Win7 listed in your sig.Thanks for that, But no support for windows 10
I downloaded original ai suite also last night and tried running in compatability for windows 7/8 but no joy it would not run
Can you not adjust the fan settings in the bios instead? Doubt you'll find a working version for 10 you'd have to reinstall 7 at a push.
Does your BIOS not have options?
Have you tried speedfan or similar apps?
http://www.almico.com/speedfan.php
https://www.reddit.com/r/ASUS/comments/7984hz/ai_suite_3_fix_for_fall_creators_update/
if your having trouble installing it check this out..it may help
