Aiming issue in Half Life
24 Feb 2004
St.Andrews
Quick and weird problem for any of you clever folk! :)
Just played HL2 Ep2 yesterday (finally! :p) and now I'm feeling all nostalgic and want to play through HL1/Op Force/Blue Shift.
Just fired it up and got through all the nonsense in the test chamber and have discovered a major flaw. Firstly auto aim was on - eugh! However after turning it off my aim is off.
When I fire all my bullets I hit roughly an inch to the right and a little bit above the target indicated by the crosshairs.
Whilst I could just make some new crosshairs to counter this is there a known fix? Playing on the following system:
Q6600
9800GT (dunno drivers)
4GB RAM
Vista 64
Playing HL through Steam running at 1920*1200/32 bit colour
Any good ideas? Or bad ideas for that matter?
No problem, I often find widescreen resolutions play havok with older games... Stick it in 1600x1200 or 1280x1024 and you should be fine.
You can probably use cl_cross_x and cl_cross_y to tweak crosshair location (these are the Quakeworld commands and HL uses a modified Quake engine)
